yeah, the delay or other fx on the vocal are a bit too heavy handed so the vocal is a tad distant for my tastes. As stated that could be helped by longer predelay so the vocal has a chance to get heard a bit before the delay kicks in. Or “sidechain” the vocal into the reverb or delay so that the reverb/delay is quieter when the vocal is actually singing and then it comes in stronger during the gaps
sometimes u also can use more than one reverb on a vocal. for instance u might have a shorter reverb that isnt mixed really loud and it stays on all the time just to give some amount of basic space or depth to the vocal and then u also have a longer/bigger reverb that is sidechained or manually turned up or down etc. You could just put the shorter verb directly on the vocal but maybe have the longer verb on a separate track and send the vocal over to it blended in to taste etc
Snare maybe a tad too loud while kick is maybe too quiet. Balancing kick and snare is one of those classic things that has to always be addressed since they can both sit around the same frequencies etc. Sometimes u have to take a spectrum analyzer like the great free one “SPAN” and find the main frequency for kick and bass. for me the kick fundamental frequency is usually lower like 60-80hz and the bass fundamental tends to be around 100ish. Then the kick can have some attack heard up around 3-4k which can help it be heard in the mix. So sometimes there are things that can be done like giving the kick a small boost at its main frequency, lets say 60hz, and then give the bass a small cut at 60hz. Then give the kick a small cut at 100hz while giving the bass a small boost at 100hz. There are a million vids about it online
Same for stuff like vocals and snare or vocals and other instruments etc
Songwise i was only going to comment that the chorus repeating without variation 4x was a little too repetitive but you changed it nicely on the out chorus so me personally Id do something similar on the first chorus…maybe just vary the 3rd or 4th repeat to something like just “weakness” or “im so weak” or “im weak” or whatever lol.
Cool song though!
just wanna say, production, mixing, engineering etc etc is HARD and then to put that on top of singing/writing/playing instruments is of course another order of magnitude harder. that being said, I think it is also the way to go for people working alone. At least that way you can put out decent sounding demos etc and eventually you can self produce stuff that sounds great and maybe just send it off for mastering and u end up with a pro sounding thing for not too much $$$
The way it has worked for me so far is that I just sort of let things flow naturally. For instance, take four of the overall areas I work on: singing, guitar (technical aspects like lead playing), songwriting, mixing. Okay, I WISH I had some sort of detailed schedule for spending x amount of time working on each area, but I dont. I take it as it comes.
So like I do my main singing warmups/exercises while driving to work 4x per week. 30 minute drive. So that gives me that background of consistency in my singing voice…thats my baseline on that.
Then for instance at the end of January I participated in a songwriting challenge where we wrote 5 songs in 5 days. So obviously I spent every second doing that during that week. other things fell to the back burner
Then at the start of February I had an unforeseen physical issue come up and I missed 2 weeks of work. I had just joined a site dedicated to mixing so basically all I did for those 2 weeks was mix songs and also catch up a lot of my guitar scales etc. But I didnt sing AT ALL! Being out of my “singing exercises while driving to work” didnt help my singing lol.
So now I am back to work and will fall back into a more “normal” routine. Since I havent really jammed much or written or recorded much in about 3 weeks, I feel the hunger for it and that is the way it normally works for me.
So whether my approach is ideal or it is a loser approach…i cant exactly say but it is what it is lol. Take it for what its worth. No ONE area improves quickly this way but they all continue to slowly get better over time.
Peace, JonJon
