So, I know the title sounds like an oxymoron, but I deliberately titled it that way, because it is kind of counter-intuitive.
In this thread, the discussion on my mix lead to both @ncls and @Lophophora asking about getting punchy, loud mixes without the need for excessive limiting on the final master buss (and the associated negative artefacts associated with heavy limiting and/or compression).
To give a short answer, I said this:
To which Phil and Jean-Marc replied:
So rather than sidetrack that thread, I thought I would start a new post. Here is my answer:
BTW, Iâm pretty sure some wonât like my answerâŠbecause this method is very ânon-puristâ⊠but here goes anywayâŠ
Itâs very simple actually. Itâs all about peak control at a track level. Especially with transient-rich sources (eg. drums, piano, clean guitars, acoustic guitars) you simply need to find a way to reduce the peak level of the transients with a method that doesnât soften them (if your goal is to retain transient punch, that is).
This is why old blokes go on about how great analogue is. Analogue equipment does this for you automatically, even when youâre not trying to do it. Tape (for example) is not capable of capturing drum fast transients - it basically destroys them. So when you slam drums into tape, the transients saturate and distort so much, it basically acts as a clipper/limiter. Of course if you slam it too hard into tape, you will get audible distortion, and sometimes that is desirable with drums, because the impact is so fast and noisy, it isnât perceived as distortion, but rather âfatnessâ, âwarmthâ, âpunchâ or whatever other buzzword applies.
The âproblemâ with modern digital capture is that it retains complete fidelity of transient information, meaning that in any purely digital capture, the peak to RMS ratio will be very high. This, of course is not really a âproblemâ, but it becomes such if you expect to treat the audio in the same way as analogue capture and get the same results.
It stands to reason, that if your peak to RMS ratio remains high across 30, 40 or more individual tracks in your project, once all those transients sum together at your mix buss, youâll have one very âspikeyâ mix⊠and if you then slam that into a poor limiter - matter how great and transparent that limiter is - your mix will be distorting long before it even gets close to hitting even modest LUFs levels, like say -15.
So basically, it comes down to this: If you tightly control the transients all the way through your mixing chain - from the track level, to the group level, the buss level, and finally the mix buss, your mix should be pretty much hitting -16 to -12LUFs (sometimes even louder!) even before you do any final limiting.
ââŠand how do you do that?â Well this is the part of the answer youâre probably not going to like, because it flies in the face of âaccepted internet wisdomââŠ
The âauthenticâ (and hence probably more âacceptableâ) way to do it is to use analogue modelling summing plugins, transformer emulation, tape simulation plugins and the like to simulate what happens in an analogue recording and mixing chain - multiple layers of analogue âspongeâ to soak up all those pesky transients.
The problem with using this method strictly, is that you run into the same problem that old analogue guys used to complain about: The transients become âsoftâ and the mix loses âpunchâ and immediacy⊠And of course, the problem with trying to be âauthenticâ is that nothing is actually âauthenticâ and it is all digital emulation anyway.
So how do you do it while retaining apparent transient âpunchâ? In the most âtransparentâ way we have access to: Clippers and Limiters⊠yes, thatâs right⊠clippers and limiters at a track, group, buss and master buss level - All the way through the chain.
Before you recoil in horror at this heresy remember, weâre talking about only limiting or clipping 1, 2, maybe 3dB at the most at each stage⊠and because youâre using it on transient rich sources, it is only touching those very brief individual transients, not the âbodyâ of the sound⊠Think about it, if you can âbuyâ 1-2 dB of headroom across multiple tracks and busses in your mix, that translates to a whole heap of peaks that arenât multiplying on each downbeat when they are summed together across your entire mix at the mixbuss stage.
So thatâs it. If you donât believe it could work, try this: Grab a mix project that is nice and rich in transients, and try just a limiter on each track where the transients need taming. Use it first in the chain, just to limit by maybe 1 or 2 dB at the most. Donât be terrified of using multiple limiters on your mix - itâs not illegal, and the mix police wonât arrest you.
You donât have to use super-fancy ones that use tonnes of CP-U - just the bog-standard limiter that comes with your DAW will be fine and probably wonât chew up any computing power.
If you do it right, youâll actually find things much easier to mix, and by the time you get to the final stage of the mix, youâll be hitting much higher LUFs levels than usual, and your mix will be punchy and immediate.
Once you get confidence in using that method, incorporate clippers into your workflow, so you can use either hard or soft clipping to suit the source material much better.
If youâre at a loss for material to practice on, here is a choice of 3 multitrack projects from my last album:
http://www.multitracks.cambridge-mt.com/FytaKyte_Bitter_Full.zip
http://www.mtkdata.cambridgemusictechnology.co.uk/FytaKyte/LifeGetsInTheWay_Multitracks.zip
http://www.mtkdata.cambridgemusictechnology.co.uk/FytaKyte/LifeGetsInTheWay_Stems.zip
@ncls and @Lophophora I hope that explains it clear enough.
⊠But just in case the original point gets completely obsfucated and side-tracked, here is a quick summary:
- The goal is to avoid heavy limiting (or any limiting, if your final LUFS targets are lower) on the master buss. This will assist in avoiding distortion and in retaining a punchy, transient rich sound. If you mix music that isnât concerned with these things, then this technique is probably not relevant to you. Feel free to ignore.
Anyone mixing modern, drum-centric music aiming at minimimum -14LUFs would probably benefit their music by experimenting with this technique.
The premise is simple: You basically use clippers/brick wall imiters on individual tracks/groups/busses upstream of your final master buss to play âwhack-a-moleâ with the very top 1-3dB of your transient-rich tracks on an individual basis.
When you control the transients upstream of your master buss in this way, these transient rich sources are stopped from multiplying as much when they are summed together in your final mix. (Remember that transients from multiple elements tend to hit all at the same time in rhythmic music).
The result is less limiting at the final stage, less distortion, and more perceived âpunch.â
PS. Discussing the ethics, the whys and the wherefores, hearing the sober cautionings of apocalyptic, pandemic-level hearing destruction of the populous related to the so-called Loudness Wars is more tiring to me than listening to Death Magnetic.
Whether you decide to crush your mix to a pulp with a limiter at the end of your Mixbus chain or not is your choice (or possibly the choice of the artist/client). Either way, IMO using this method upstream of that will still yield a better result.
Yes, those are tried and true good plugins, though I donât seem to use the IK Clipper nearly as much as I probably could, so among a few other points that is something this thread reminded me to check back in with and explore further.
but it does have some common elements to the topic.
