What is your favorite plugin for (Roland) 808 sounds?
The Roland 808 drum machine? Or the TS-808? For the Tube Screamer Iâm fond of Ignite Amps, the plugins TSB-1, inspired by the 808.
Their TS-999 is pretty bitchinâ too, a more faithful adaptation of the 808.
If youâre talking about the drum machine, then this is the one I use and the only one I know ofâŚ
https://www.pluginboutique.com/product/1-Instruments/7-Drum-Machine/376-TS-808
Sorry! I wasnât even thinking! I meant the Roland 808. Good catch!
Then allow me to shortenâŚ
This one is what I use, and itâs free. I like the UI, itâs pretty versatile and I used it on my âErotic Dishwasherâ track. I switch between it and the LinnDrum (with extreme pitch manipulation) for electronic music.
Unfortunately it says it is PC only
Hereâs an example of what you canât have then⌠the toms are Simmons though.
Whatâs your OS?
Right now NI Maschine with a mishmash of their expansion libraries. I have the Arturia Spark, which I thought would have done a better 808 since theyâre really the kings of analog synth modeling imo. But the Maschine stuff is a little easier to dial in.
I also use Geist, Battery, and MOTU BPM. Rob Papen also has some pretty usable stuff. Theyâre old, but they work, and I know my way around the libraries pretty well. However, Maschine is really my go-to default for 808.
I supplement 808âs with the Waves R bass, the Boz Sasquatch, XLN trigger packs, and the Arturia Minimoog sample bass. Oh yeah. And U-He Zebra has some cool and usable drum stuff.
Iâm running PT on a Mac
I had the exact same experience with my Spark. Thatâs exactly why I was asking actually. Lol
I came to the conclusion Spark was a phase in the Arturia company where they were feeling out if there was a market for hardware/software integration. Theyâve clearly found their niche, but not on the analog drum machine side. I donât know if its because their TAE tech doesnât play as nicely with 808âs as it does with Moogs, but I thought the Spark 808 patches were bland.
@bozmillar or @ikmultimedia may have some thoughts on this, but I believe weâve gotten pretty accustomed to hearing the plugin makers idea of what they anticipate the user âwantingâ the emulation to sound like, more so than being dead on true to what the emulation âdoesâ sound like. A good example is that 9/10 people will probably prefer XLN addictive to BFD3, because the snares and kicks appear enormous, strait off the cuff when you load them. When you unload the FX, and account for the compression that was committed to the Addictive sample, I believe Addictive and BFD are dead equal. Except for the fact that BFD has a much larger and far more diverse set of add ons. But it takes a little longer to get the BFD sound processed and production ready.
Iâm going off on a tangent here, but for sample replacement, the question isnât XLN vs Fxpansion. The question is: âwho sampled the kit piece closest to the one I need to sample replace?â. Beyond that, its down to interface. Its a different question for the 808, because thereâs only one sample set in question to begin with (opposed to a selecting from a variety of kit pieces). So to me, it then comes down to which one gets you up and running the fastest.
So true. With any of these plugins we tend to expect the sounds or effects to instantly be what weâre hearing in our heads ahead of time. Thereâs a built-in bias that totally varies from user to user.
Limited needs with me, but Iâve used TS-808 - fine and free!
Yeah, I may need to just throw reaper on an old PC and try it out since they donât make a mac version of the plugin.
