Looks like a good deal.
I’m curious about the Axe I/O, in particular its latency performance. Reading through the IK description of the hardware it is only mentioned as an aside right at the end. Not a good sign knowing that this will be on guitarists minds as a number 1 priority (I assume). Can you record with amp sims and pedal sims turned on?
Yes, you can. I am not getting a fantastic latency on this, similar to my other USB interface which is a Roland UA-4FX, about 4-6ms, then once you load it too much it starts to lag.
It just might be my mahcine though, I am running 32bit as well, but won’t touch to upgrade until our LP is complete as we’re in the middle of recording.
