Just wondering what would be viewed as minimum requirements for a computer to produce music?
My computer is a 2011 MacBook Pro i7 8gb ram. Is that about right for a beginner?
More than enough!!!
My first fiddling days where on a pc that could barely run frutyloops
lol So I think your fine
Perfectly fine. You should have ample resources for more than just beginner levels of recording. Good luck!
You should be fine.
Thanks for the feedback.
+1 for using what you have. It should be just fine for getting you started. Have you figured out which DAW youāll go with yet?
Ok thanks.
Iām using Logic Pro X
Do you know what most on here are using?
Thereās a wide variety of DAWs in use by folks here. A lot of people use Reaper; also Cubase, Nuendo, Logic, Sonar, Studio One, Pro Tools, Mixcraft, Samplitude (not to be confused with Samplitube, a set of guitar amp sims), and others yet. Try a few out and see what seems most sensible to you. They all do pretty much the same things, in similar ways, and what ends up happening to almost everyone is that one settles on something that makes sense for whatever reasons, and they sticks with it. Rare for people to change once they become familiar with a particular DAW and have invested significant time into learning its ins and outs. So the time to test-drive is up front before you get to that point.
If I had to guess, Iād say the majority here probably are Reaper users. It is a full-featured product for a very low price. Iām in the minority as a user of Mixcraft; itās probably second in terms of bang per buck owing to its similarly low cost (but itās a bit more than Reaper). At the other end are products like Pro Tools which have versions that are quite expensive.
You pays yer money and you takes yer choice!
I used Cubase for a number of years, and Iām learning Reaper. Reaper is a very cool way of going, since it is cost effective, has most of the plugs you need, and you get free upgrades as you keep going. DAWs donāt vary a whole lot in what they accomplish, and a lot of your choice becomes based on how you like the GUI. Reaper to me is easier to learn than Cubase, and although the initial look of the GUI is not very fancy, you quickly find out you can do whatever youāre thinking with a little research. I donāt think youāll find noticeable differences in sound from one to the next, but you may find that a particular one has a feature or a plug that makes it attractive.
I think youāll be fine. I have a late-2008 MBP that I still use a lot for fairly complex stuff. I even ran Pro Tools on it (and still can) but there are some limitations of CPU and RAM (4GB). Reaper is much lighter on CPU which has helped as it gets older. The only big problem I had was after I got Slate Digital SSD4 drums, it seemed to max out the RAM for the system and crash sometimes. But that was with Pro Tools, which may have been half the problem. The cooling fans will run high and make some noise while mixing, but if you turn the studio monitors up loud enough it wonāt bother you. :beerbang:
Since youāre a Mac guy, Iām curious what OSX youāre running and what your experience is with different versions if you have been through that. I started with Leopard and only upgraded to Snow Leopard out of necessity for some compatibility things. They are way past that now, and Iām seeing that Iāll have to upgrade again probably. When I do that, Iāll lose the Pro Tools (old) install functionality which is fine. Maybe some other things too, but hell I guess thatās progress.
I think I can only go up to El Capitan with my specs, but Yosemite is looking like perhaps the optimal for me.
Iām running that same laptop actually, on a 15" i7. I had it loaded to the full with stuff I didnāt need. Iām now running Logic on it, and I get a system overload error once every few months when Iāve taken my plugins a little too far.
Hi Stan
I have El Capitan and have no problem. Iām using Logic Pro X so I would assume they should work together.
One thing I do notice is that it doesnāt take much for the fan to start going pretty fast.
And I get that overload error from Logic pretty often usually when I try to change a plugin while itās playing.
Not sure if these issues are normal or not so thatās why I posted the question.
Yeah, the Logic system requirements should tell you which OSX is their minimum spec.
Yeah, fan is quite normal. A laptop is an electrical sandwich. Heat builds up pretty quick. I track the fan RPMās just to keep an eye on it. And the heat sensors. I find the iStat Pro (free) widget quite helpful for that.
Some DAWās or computers seem challenged with that āliveā plugin swap. I had some issues with it using Pro Tools, but Reaper doesnāt seem to mind. I think itās a CPU challenge mainly.
Ok. Thanks very much for that info. Good to know.
Reaper is mentioned a lot in these threads⦠would you guys recommend this for someone starting out on home recording ventures for a complete beginner like myself?
I suggest trying out demoās of any DAWās that you can, then decide which one to go with. Yes I would recommend Reaper as a good start, but thatās something youāll need to see for yourself. Some great things about Reaper:
Some potential challenges with Reaper:
All that said, if you start with the DAW youāll end up staying with, each one has a learning curve. And with Reaper you donāt need to learn any more than you want to (besides basics), until youāre ready to tackle something new.
Hey Ailwynā¦Die-hard Reaper convert here, and I agree with all the points Stan made.
I have actually have trialled and/or own a LOT of DAWs including Pro-Tools, Cubase, Sonar, Ableton Live, Reason and Harrison Mixbus, so I feel I can be fairly unbiasedā¦
However, if you try Reaper and find it too intimidating, I have another suggestion that I would wholeheartedly recommend - Mixcraft.
Mixcraft was the very first DAW I used and it is super easy and intuitive to get your head around. I started off on Mixcraft 3, but they are up to Mixcraft 8 now, and it has matured into a very capable and advanced product, with most of the features available in other top DAWs. Whatās more, itās very inexpensive, and comes with lots of virtual instruments and plugins. Hands down, the easiest DAW to use IMO.
http://www.acoustica.com/mixcraft/
Another one to consider is Studio One (I think itās up to version 3 now). I have their free variant of version 2 installed on my computer, and it was very easy to get around, with lots of great features. If I wasnāt already so far invested in Reaper, that would probably be my current DAW of choice.
http://www.presonus.com/products/studio-one/
Oh wait - One thing I just thought of - It depends which OS you have on your computerā¦If you are on Mac like the OP @MisterLevy , then scrap the Mixcraft suggestion⦠Reaper and Studio One have Mac versions, though.
If you are on Mac, you can record and mix perfectly well (albeit somewhat limited) in GarageBand, which should come installed already on the computer as one of the standard programs⦠At least it was on my wifeās 2009 MacBook. Iāve tried it too, and itās much like a basic version of Mixcraft - very easyā¦So Iād suggest getting to know that first. The ābig brotherā of GarageBand is Logic Pro, of which I have had no experience with, but by all accounts is a very comprehensive DAW for relatively few $.
Plus one jillion for Mixcraft. Thanks Andrew for giving it a solid recommendation. I find it SO easy to use. Itās never not been able to do anything I can think of, and you can be up and running really fast. Only a bit more expensive than Reaper and from what Iāve read and seen, a whole lot easier to get going with.
I will also give a big thumbs up to their support. Iāve always gotten very quick, very thorough replies to all my queries. There is an active user base and support forum on which the devs themselves are very active. And there is no question at all that it makes top-quality recordings. @AJ113ās work is all done with it, and Iād defy anyone to say his stuff is subpar in any way.
Good luck!
When I first started recording digitally many moons ago I did my reserach and plumped for Mixcraft. Iām still with it and Iām not likely to jump ship any time soon.
