Will 96k be the new standard?
A great explanation @Stan_Halen. Thank you!!
The ultra sonic and subsonic frequencies affect what we do hear. These harmonics are in the ranges that can’t be heard by the human ear but, they react in a way that gives an instrument it characteristic sound such as piano and stringed instruments in particular. When these instruments are recorded at low sample and bit rates these frequencies are lost and many instruments don’t sound right and are fatiguing to the listener just as mp3 are. This is because the brain is trying to piece together the bits and pieces that are lost in the conversion and or dithering. At higher sample and bit rates more of this information is recorded to the point where at 192k/32 bit and above, the recordings are approaching the capabilities of tape that capture most all frequencies and sound the most natural. This is also why there is a resurgence in vinyl and even cassette tape sales. CD’S could sound much better than they do. We have the capability to, why not?
That may or may not be true, but you aren’t reproducing those frequencies simply by increasing the sample rate. Microphones, amplifiers, filters and speakers are all designed and built to operate within the human range of hearing, i.e. 20Hz to 20kHz. You’d have to redesign and manufacture the entire chain to have any chance of hearing the effects.
Simply not true. It is a proven, accepted, scientific fact that a soundwave only needs to be sampled a maximum twice in order to reproduce it perfectly. It is an impossibility to record ā€˜more of this information’ when you already have all of it. It’s like buying an apple, and then buying more apples so that your first apple somehow becomes more ā€˜appley’. It’s totally flawed logic. Further, the ā€œcapabilities of tapeā€, even if you refer to the finest machinery ever made, never extended past a bit depth of 13.
Bit depth (I assume you mean bit depth and not bit rate) is a statement of headroom/noise floor capability. That is all. Even 16 bits gives a colossal headroom of 96db, only the most specialised of applications could ever justify needing more headroom than that.
Higher bit depths are useful inside a DAW because of the multiple tracks; the sum bus can get overloaded at 16 bits. However, this is nothng to do with ā€˜sounding better’, it is simply easier to operate, with less chance of clipping the sum bus.
Further, at 192kHz, the sample rate is so fast that errors are inevitable. So not only is it a rate that is totally unnecessary - literally - but it degrades the sound quality due to errors of speed, thus completely defeating its own (alleged) purpose.
How would you do that? …Suppose someone wanted to.
That is my point. You couldn’t, therefore it’s pointless using 96kHz for the purpose of an extended high frequency range.
Even if you could somehow manage it, there is still the problem of the general listening public’s equipment.
I misunderstood what you were saying. So that makes sense.
Some monitors have a shelving configuration up to 40k. Mine sound different in full range mode. I don’t care if most people can’t hear it, I find it easier to make mix decision with everything in full range, then reduce to standard mode, then reduce to 2 way, then reduce to mono, when checking for translation at the very end.
…I wouldn’t claim this has anything to do with 96k though.
It makes sense that anything with electronics or ā€˜manufacturing’ such as speakers has the limited range, but as DaveP specifically mentioned piano and strings as cases with extended harmonics isn’t it possible that some fine acoustic instruments like that could (theoretically) benefit from being recorded at higher sample rates? In other words, if they demonstrate harmonics above and beyond half the Nyquist (22, 050 Hz) then they might not be fully reproduced by a 44.1k sample rate?
So you’re also citing Nyquist here? As per above, I would ask that if the soundwave did happen to be beyond human hearing (or 22,050 Hz) with harmonics/overtones then it’s possible that a higher sample rate could conceivably capture a tiny amount of subtle harmonics that would impact the more fundamental (lower) frequencies? If so, I think we’re looking at very subtle differences and nuances that might only be heard by the most discriminating audiophile. I’m just trying to be clear on the discussion.
As to tape capturing all frequencies and sounding more natural, I would tend to think that since tape is mechanical/electronic/manufactured that it also has limitations on capturing a wide range of sound. Tape technology was notorious for high-end roll-off; losing higher frequencies. And the electronics contained filters, whether intentionally or by the action of capacitors etc. Rather than saying it sounds more natural, I would say it sounds more ā€˜pleasing’ to some people (due to the inherent recording limitations). It could be said that analog does sound more natural or pleasing because to some degree it emulates how our ear/brain hears things. A long standing complaint about digital (whether deserved or not) is that it sounds too ā€œclinicalā€ and ā€œsterileā€. In other words, it’s not ā€œdirtied upā€.
But do you still subscribe to the info you referenced in Post #34 that recording at 96k might have some practical benefits in terms of electronics (aliasing, filters) and processing?
I don’t have the faintest clue how this stuff actually works. My question would be the same…if 23K audio can effect what we can hear based on the fact that energy waves from energy clearly interact with each other. That raise the question is we can hear the result of the interaction. I don’t know…
I do buy into the theory that subtle matters. Dave Hill at CraneSong scientifically demonstrated that jitter differences between DA converters is audible, and that that jitter from an Antelope and Big Ben sound different than jitter from and Avid i/o.
Isn’t that supposed to be the reason izotope plugs upsample to the 384k?
I think AJ mentioned earlier that some plugin processing can be more efficient at 96k (or whatever higher sample rate). I’m guessing that is a kind of ā€˜oversampling’ which might do something similar to the time-stretching effect you mentioned, where using a higher sample rate just minimizes distortions and errors in extreme circumstances.
Keep in mind that just because a manufacturer touts an impressive spec doesn’t necessarily mean that it improves anything or makes a difference. Such things can be used as marketing tools simply to get people to drop their jaws at NAMM or look better than the competition. I’m not saying it doesn’t do anything, just that I’m skeptical of marketing claims.
If I recall correctly, Boz said the code in that izotope stuff is real deep. There’s a lot to be said for who’s using it as far as taking advantage of those cutting edge features. I’m not one to say if the up sampling algorithms are truly beneficial, because I don’t have anything to compare it with. I’ve only ever used Ozone for makeshift mastering stuff (that we all know is not really mastering). lol.
As much as it gets me by for what I need it to do, its not a plugin that I’d swear by, because I don’t anywhere close to enough experience in mastering to know.
Yes, of course, I didn’t deny that.
I said that it’s flawed logic to assert that simply increasing the sample rate to 96kHz is going to produce the desired effect. Even assuming that reproduction of the higher frequencies somehow became possible, you would then have to deal with assertion that it actually makes any kind of discernible difference.
Certainly we are talking about subtle differences. Whether anyone at all can tell the difference is debateable. As far as I am aware all experimantation thus far has shown that nobody can tell any difference at bit depths higher than 16, and sample rates higher than 44.1kHz. I mean, I’m not close-minded about this but it doesn’t look good for the high sample rate camp currently. However, that state of affairs does not seem to deter manufacturers and people who have bought their products from claming otherwise.
Yes of course, I did my first 96kHz recording a couple of days ago. I would have reported back to this thread but the only thing I have to report is that I haven’t anything to report. I did notice the computer slowing down a little bit but I couldn’t say for sure that it was due to the 96kHz rate.
Ha, well I guess that’s not unexpected. Kudos for trying though.
I assume double the samples means more work for the computer. I seem to remember that (theoretically) there is a heavier load for a higher sample rate than there is for a lower sample rate, given the same latency and other conditions. It would seem to make sense. That’s what I learned IIRC, but haven’t ever tested that out.
Now you guys have me curious. I think I’ll sit down next week and see if I can do a quick acoustic thing (maybe voice and guitar) at 16/44.1, 24/48 and then again at 24 or 32/96.
Run it through a couple different spectrum analyzers, warp the crap out of it. Just generally beat it about the head and shoulders and see how each one holds up.
Super scientific testing methods.
Here is an interesting article in SOS that discusses the pros and cons:
https://www.soundonsound.com/sound-advice/q-should-i-use-high-sample-rates
Good article! I didn’t even think about jitter being introduced as you increase the rate. Good point!!
I thought about doing this as a test too, may still do it. My idea was to use 2 of the same mic (I think mine are even a ā€œmatched pairā€), use one mic going to one computer recording at 44.1k, and the other mic right beside it going to another computer recording at 96k. That might try to get things as similar as possible (same performance) for comparison results. While some may not have that kind of setup, I happen to use two different computers (Windows and Mac) for recording, depending on what and where I’m recording it, and have an interface for each.
I’d love to hear the results! Although, it’s not quite as identical as you’d probably prefer given the PC and Mac involved, I think it’ll still work for this purpose!
Yes, having exact same computers and interfaces - everything the same - would probably be more objective. I don’t know that PC and Mac would record the sound differently, but they might. Mac is usually recommended for music recording (in some circles) because of ease of ease of audio configuration and workflow, and perhaps other criteria. It doesn’t record sound better than Windows is my understanding.
Identical interfaces might be the more crucial issue, preamps and converters, same settings, etc.
