Hi,
I just downloaded Sonatina double bass, a free vst plugin.
But when I try to load it in cubase I get this:
Any suggestions?
Hi,
Any suggestions?
Iām not the guy to answer this question but check to see if itās in your VST plugins folderā¦Iāve had the same issues before and I donāt specifically remember how I fixed the situation, but I think itās just a matter of finding the plugin in your computer and directing it to your DAW plugins folder. Someone else will probably chime in and explain it way better than I can.
Yep to what Wicked said⦠Iāve often had to faff around with new vst instruments⦠find where all your others are stored then locate the new one and drag it on over. You are looking for the dll. file.
Plus you sometimes need to refresh the list, there is an option for that but I think simply re-booting cubase automatically does that. Not at my computer at the moment sorry. Let us know how you get on.
Is this stand alone vsti? Or does this need Kontact sample player?
Sorry for the late reaction. Havenāt had a chance to come online since then
Well, when I downloaded it, it had no installation file, just a .ddl and a .mse file.
So I put the .dll file in the vst plugins folder, so I could find it in cubase, which I did, and opend as a vst instrument, but then I got this message.
On the ābigcat instrumentsā website, all of their instruments require a version of Kontact player (greater then Kontact 5)ā¦so maybe that is the problem?
Ah ok :s Yeah, I know close to nothing about these things Iāll check it out!
Thanks !
