One of the things that I saw really drag recording review down was when Brandon “declared” that buying “fancy” gear was a waste of time and expense. It meant that subjects about new gear coming out tanked and frankly gave us much less to talk about. To be clear I do not think Brandon was completely wrong. I am also not wanting to start a “Bash Brandon Thread”. I am just wanting to say a few things that I felt alienated me in later years at the RR forum. I certainly have wasted my fair share of cash on high priced gear and this is my opinion. I do not declare what I am about to say as fact.
Here is where I thought Brandon was correct.
Daw plugins are much more powerful then they are often given credit for. Any Daw eq can be the heart of your mixing tool belt.
People should be encouraged to record with whatever gear they have.
A person doesn’t need a rack full of Neve’s to make a radio quality record.
Room treatment is paramount
Monitors are important.
There are plenty of low budget mics, pres and convertors that are fantastic.
Analog summing is a scam. Daws sum as accurately as is possible.
The following is where I disagree with what I perceived to be Brandon’s hard line approach.
Mic pre’s do make a difference. I have had the pleasure to use pres from all over the specturm, API, Shadowhills, Audient, Mackie, behringer, presonus, soundcraft, midas, focusrite, etc, etc, etc. What I found was that you can get pres that work and not spend a ton of cash. My D&R pres stand up just fine to API’s for example. Also needing a million different types of pres is just not necessary. Brandon seemed to think the behringer pres stood up as well as the high priced pres and maybe they did for him I can tell you that they don’t for me. I have had to mix a few live shows done on x32’s. They make me work so hard when I mix they just aren’t up to the standard that I would consider for a pro studio. He loved a particular Rane mic pre. I never tried it. I hope it is awesome. The biggest difference I’ve found with quality mic pres is that when you mic up a source you get what is in the room in your monitors. Those micro mic moves that drastically change the sound are lessened and they become more sideways moves as opposed to good and bad decisions. There are plenty of “budget options” that are lateral moves from API, Neve etc. Having a quality pre matters. Spending a reasonable amount to get them is the game to win.
A DAW has all the plugins you need. Im not actually sure that Brandon believed this but the push was on to make this a reality. Most DAWS have very useful plugins and a lot can be done with them. I certainly have experimented with this and it didn’t take long to see that mixing with only ITB DAW plugs would be very time consuming. I am sure Boz is not creating plugins with the mindset that they are all useless and can be recreated with DAW plugins. I will state that given enough time DAW plugs can get you really far.
Convertors - Brandon and I were farily close on this one. I think far too much time is spent on debating the importance of convertors. I did an experiment shooting out an Orion 32 against presonus convertors. Clearly it was harder to get the clarity out of the presonus then the Orion. The transients on guitar picking was 1000% better. Like mic pre’s I have found plenty of budget convertors that “play with the big boys” well enough.
In general I found that Brandon was on the hunt to convince himself that you can record a blockbuster album for a few grand. Not that it has never been done or couldn’t be done. Factoring in work flow, time and quality this is certainly not how I would like to function.
Can an under $200 mic get you “THAT” vocal sound? Sure. Will it take a bunch more time? Most likely. Can you get the top quality stellar sound that is sometimes needed. That is debatable. If you are recording metal screaming vocals or vocals that are always in dense mixes you have much more leeway. If you need to get a beautiful robust vocal with only one other instrument I would say not unless you have the worlds best vocalist in front of you.
Okay rant over! To balance out this rant I was feeling like it was not acceptable to talk about liking outboard gear and the advantages I find with it. On the other hand I have no interest in having members feeling inadequate for not having the latest greatest gear. I admire many mixes that people do purely ITB. If there is any real advantage of hardware it is about how we get the sounds to the DAW. I think we can all agree that tracking well is paramount.
