So, either the VST doesn’t work with Cubase 6 (the update on the webpage suggests it was last under development in 2006), or I’m looking in the wrong place.
Can any of you advise me, please? Or can you get the VST playing nicely?
I’m not a Cubase user, but I sit with my friend to mix and he’s been using it for a decade. I can remember that when he adds his synths into Cubase, he pulls up an Instrument rack and puts his VST in there, rather than what I do in Logic (create a new synth track and add a VST directly into that).
Yeah, I found another video shortly after my reply, but didn’t get long to try it out before I had to head off to work. Thanks for the info though. I’ll take a proper look in about 8 or 9 hours…
I need to clarify something… The Taurus bass pedal is a hardware controlled soft synth emulator? Correct? This thing is essentially a keyboard/synth virtual instrument…right?
Show me what it gives you when you instantiate it in the new tracks window
Nuendo and Cubase do not support mixed mono/stereo like S1 and Logic. Like in Pro Tools, you can not toggle a channel/track back and forth between mono and stereo. Nor can you place stereo content on a mono track (Like in Ableton). In Nuendo, when you instantiate the channel form the New Tracks dropdown, you must declare it mono or stereo and you can not change it later. I suspect this is the problem.
