Running out of time and pretty much burnt out on this track, I submit this track for bashing.
I still need to work on the ending but I’d like an opinion on the mix so far, whats working for you, what isn’t? Don’t be shy, it can only help!
I think you’ve got a great, balanced mix going on. Everything is audible and sounds good as an individual piece. I REALLY enjoy the vocal sound you have, but it sounds disconnected between the drums and the rest of the band. I think you should do a little tweaking with your verbs and other chains to get everything in the same room (or closer to it).
That’s my two cents. Cheers!
Pretty good already
Main issues that came to my mind:
Solo guitar in opening maybe a bit too harsh
Bass is maybe too full in low mids, or too much low end in the whole mix.
Bass lacks definiton. Listen around 1:40 when bass has to lead the groove.
TOm fills quite weak: listen around 1:50
Nice balance and mix
Clear vocals. The bass could be cleaner.
And the guitars may be fatter (slightly)
You did a nice work
