Also couldn’t find any fix from what I’ve seen on Reaper forums.
I am thinking that possibly there might be some kind of startup.ini file that this value could be overwritten. I rather not reinstall again as it will probably break up all my validated software and I have to re-register. This changed recently though, as I have no idea why. Possibly after I installed the latest Cakewalk by Bandlab (Sonar).
What I do is go to the plugin folder and move the trouble maker to another folder (desktop) so that I can get back into Reaper and then adjust the path for scans ( or maybe give up on the bad plug.)
You might have to move all the DXi ; but that’s not hard to do.
DX (Windows Direct X) plugins don’t rely on scan paths, but on registry entries.
You may have a incompatible plugin installed and it is hanging the DX scan.
Here’s a link to a freeware DX manager that allows you to disable/remove DX plugins and that may help you progress: VB Plugin Manager
Don’t want to break anything else as I am in the middle of finishin up recording session. When I am done I’ll try to reinstall Reaper, but Reaper is not essential to my wrokflow, just wanted to test its noise removal plugins.
I don’t even know where to look for these direct x plugins which I am assuming are conking out. From what I understand they are installed with registry hooks. Sounds like a valid idea though.
On my set up Cakewalk Sonar has some DXi plugs which you can see by opening Sonar and going to Utilities > Cakewalk Plugin manager > DirectX effects.
On my set up I can run some of these in Reaper by including them in the Reaper plugin folder. Maybe by comparing the two folders you can find the problem.
Here’s a screen clip of the VB Plugin Manager freeware that I have linked above:
It will scan your Windows registry and display all of the installed DX plugins and also allow you to disable/remove the plugin.
You can disable a suspected plugin and restart Reaper to see if it fixes your problem.
If not, then use it to enable the plugin and move on to the next suspect.
If they were installed prior to the Reaper problem, then they are most likely not the problem.
Tracing down problems on a Windows system can be a painful process.
OK, fixed it on an advice from a guy on another forum. The Reaper folder in the Start menu of WIn7 has a “Reaper-Show audio configuration on startup” option, that seemed to flush whatever was going on.
Super weird…
