Excuse me if this is not a new product but just got email from Radial on this - looks great for rackmount. Currently running a Juice Goose that is a bit too primitive. Anyone have this one, and if you do, thoughts?
Looks amazing! Iâm really impressed with the outlet layout on that one. And the fact that they put 3 on the front vs just one. Very clever design. I suspect the quality is good. Radial makes some decent stuff. Thumbs up from me!
Itâs a standard rack mount power distribution unit that uses a MOV for surge suppression.
Their marketing edge is that the MOV (metal oxide varistor) is made in the USA.
MOVs are destructive devices, meaning that with each over voltage surge they block, physical damage occurs inside the device. They do not protect against long term over voltage/current surges or inrush situations, but are effective for short term events. It appears to have basic EMI/RF filtering inside.
Specifications are: Load Rating: 15 Amps Max Continuous Operating Voltage: 130V-rms Energy Dissipation: 210 Joules Peak Impulse Current: 20,000 Amps Noise Attenuation: Differential-mode = 19 dB at 100 kHz, 41 dB at 1 MHz, and 42 dB at 10 MHz Common-mode = 10 dB at 100 kHz, 41 dB at 1 MHz, and 50 dB at 10 MHz Surge Protection Method: Single mode, line to neutral
Itâs a good price and Radial has a good reputation for building solid devices.
Seems like a handy layout. I would guess there isnât any real âpower conditioningâ going on, if thatâs the sort of thing you care about.
I like the fact that the front plugs arenât tied to the switch. Better than the âpower conditionersâ I have on my setups (aka rack mounted power strips).
Honestly, I canât, other than the price and the fact aside from the product name, nowhere in the description does it mention anything beyond surge protection.
âPower conditionerâ has a fuzzy definition and can range anywhere from âmight protect your gear in a lightning strikeâ to âkeeps power steady and noise free.â
I have a couple âpower conditionersâ that are nothing more than a rack mounted power strip with a fuse. They are useful, but they certainly arenât cleaning up any power issues I might have.
This spec tells us that it is filtering out high frequency content which helps with RF interference.
Unfortunately, most people have problems with 50 and 60hz hum, mostly due to ground loops, but one wouldnât want to filter out 60hz in a power conditioner.
Surge suppression just uses a MOV to send short term over voltage spikes back onto the neutral line before it reaches the device plugged into it.
Power conditioning usually means performing EMI, RF filtering and can also entail the use of power regeneration where the incoming AC is converted into DC and then back into a 50 or 60hz AC sine wave.
Regenerators are more expensive due to the additional complexity.
There are a lot of unfounded claims in regard to power conditioners, but they are popular among audiophiles who swear that it âlifts a veilâ or âblackens the backgroundâ when used.
Power conditioning and surge suppression are supposed to be different functions, but manufacturers are pretty lenient with their descriptions, as Boz pointed out.
The specs on this one donât really tell you much about either. 210 joules dissipation, if they are using that for surge suppression, is very modest.
As to power conditioning, a high end power conditioner will typically take what comes from the wall, filter it for noise and power inconsistencies, and send it to the output minus the junk. They will often include large caps to store the power for a very short period n the filtering phase.
Radial builds great stuff, and Iâm sure it does what it is supposed to do, but the specs arenât conclusive.
considering your assessment it seems you know more than I do on this topic. It kinda sounds like it is pretty much a hyped up power strip with not much happening.
Are the Monster strips better? Maybe I need to invest in something like this live as for example on one of my last gigs my tube amp ran at what seemed like half power because of dirty electricity at the venue. My amp was essentially half distorting live a mosquito
The venue was bad though - sound man was working with isolating glove to decouple himself from the stage . Thankfully, I lived.
Well, based on my limited knowledge of the Radial piece, I would just suggest looking into Furman, Monster Cable, Panamax, and do some comparisons as far as specs are concerned. In general, true power conditioning is expensive, at least in high end home audio, where youâre trying to squeeze the last drop of sound quality out of a $10,000 power amp. All amps have filters in their power supplies, although this would be an afterthought in most guitar amps. When the venue has crappy power, thereâs only so much you can do beyond verifying all your grounds are good, and trying to isolate what is causing the most noise.
Surge protection is less expensive, but designed to prevent catastrophic failures due to a rapid jump in power, Cheap ones use components that blow up when a fast pulse above their limit occurs. Unfortunately, they still allow power to pass through after the event, turning your surge suppressor into an extension cord. A good surge device will tell you how many joules it can dissipate, and importantly, how quickly. I have both Monster Cable and Panamax throughout my home in Florida, the lightning capitol of the world, and theyâve saved me a lot of grief.
Check out Furman and Monster in their music line. Also, if you play outdoor gigs, find out if thatâs covered by their warranty. They sometimes ask for a very detailed description of your setup if you need to make a claim. In short every part of your setup relies on every other piece to be protected and connected through the same suppressor.
Working in IT - those warranties always have an out, really bad experience with all the major manufacturers, no one would cover anything, it is so vague and so many lawyer loopholes that Iâve had several claims where the owner of the gear just gave up. Just want to mention that I wouldnât really rely on that.
Thatâs true. Manufacturers are generally pretty good about replacing the piece itself, but getting them to pay for the connected equipment can be a challenge. They often require documentation of how everything was hooked up to verify that every input and output was covered by their piece, which is next to impossible in a complex system.
I will say that they have been reliable in terms of protecting my home stuff, but if my house took a direct hit Iâd be negotiating with my insurance company.
A touring band is at the mercy of the venues they play, so any protection you can get helps. As far as big acts go, theyâre using outside companies for the PA whom Iâm sure have taken conditioning and protection into account. Itâs more difficult for the weekend warriors to do much more than have enough juice to make it work and try not to get shocked.
