Plug in for 12 string sound
I’m working on a song that could really use an electric 12 string, but my wife is pretty sure I’m 4 guitars over the limit right now.
Has anyone found a good 12 string sim? I’ve tried just adding an octave up with a JS plug in Reaper, but it is warbling too much for my taste. Any help?
I bought a cheap 12 string acoustic with a built-in pickup, last December. I bought it online (Amazon). It sounds fairly good. It’s amazing what kind of guitars you can buy for such low prices these days.
You can probably find a very usable 12 string acoustic for less than $170 USD. Don’t tell your wife and she probably won’t even notice that you got another guitar. :smile:
Maybe I’ll post a recording that I did with the 12 string. I was thinking of posting a song in BTR, soon.
You could capo up and add a harmony part or else do a Nashville tuning (buy 12 string guitar strings and restring a second guitar with some of the strings an octave higher) and layer a 2nd part.
That’s what I do, though you can these days buy a separate set of Nashvile tuning strings. I have them on a (very) cheap guitar which my stepson left behind. That’s OK, you don’t need a great guitar to mix in the Nashville tuning. I use it only for this purpose. You do need to play pretty tight to make it convincing though…
Yeah, there are great guitars out there for not a lot of money. For this song, the 12 string would be for orchestration, and would be electric. The reason I was looking for the sim was to give me noodling time to work out parts. They’re generally going to be up the neck a bit, where an acoustic might be difficult.
Thanks for the suggestion, I’ll look around a little and see what’s out there.
I thought about the Nashville tuning, but it might be hard to play it twice to get the octaves right and make it smooth.
It is probably the best solution for a one song deal. Thanks.
Playing one part tight is hard enough, two would be a challenge. I’ve never tried the Nashville setup, but it might be a good option. I’ve never seen a plug-in for 12 string; doesn’t seem like it would be too difficult to add octaves, but maybe it is on multiple strings.
Hey - if it’s good enough for David Gilmour???
Not tried this but I would go for:
Duplicate the track, pitch the duplicate up an octave and add chorus, then blend in with the original to taste.
Thanks AJ, good to hear from you. I’ve actually tried that, but it sounded bad in the top end, like the top strings were warbling. It might work if I mute or remove the E and B strings, but the chord voicing might be difficult.
