Hi everyone ! My entry for the contest here
This is just a regular mix, nothing special goin’ on!
Thank you for taking the time to listen and note !
- 1
- 2
- 3
- 4
- 5
- 6
- 7
- 8
- 9
- 10
0 voters
0 voters
Commenting as I listen. Nice tight intro, when they come in the vocals are underwhelming (too airy/reverby for me). Balance is good for the most part and the song builds nicely. THanks for sharing.
Bashing as I listen: the snare sounds overly compressed, too much smack and little sustain.
I agree with red above that the vocals could be more present. I’m not sold on the reverb on the LV that is a bit too bright, some high shelf cut or HPF would have helped here.
Overall not bad, but for these nitpicks. Good luck!
sound over compressed. I think it need more sustain, especially drums. IMHO the overall mix too wet too.
good luck!
Hello. My impression. A bit unnatural sound, especially the drums (maybe needs more air and space). Overall too synthetic, for this genre of music - to my ears.
It´s only my point of view, of course!
Drums don’t breath properly due to the compressor. I wonder if the vox is too effected and distant? Vox and the band are not in the same room.
A bit too much compression in the low freq, and need more saturation in the mid range. IMHO.
But good try from the vocal. It depends on taste, I think! Good luck mate!
Cheers!
Coloured mix!
Sounds a bit overcompressed and over-effected.
I like most of your balances, I would just separate the elements by widening your frequency spread. Higher highs and lower lows will make more space in the middle… (I think Benjamin Franklin first said that… ) Good work!
If you get the chance, please listen to my mix and comment; I’d appreciate it!
I just posted on your brothers mix Tokiojo Anyways,
Well no use in sugar coating it .I guess if it were me I would turn everything off on the master track the 2buss whatever you call it and see what it sounds like. If that wasn’t working I would go to each group(drums ,Guitars, vocals) and turn all processing off. Then turn each one back on listening to what each thing is adding or subtracting from the sound…
I think by doing this it will help with the bass pumping ,the mud and also help to clean the mix up.
I do find myself doing this sometimes it sucks ,but it forces you to listen to things more closely. Also, put a reference track into your daw can help .
Rapidly :
You should try to be just more gentle on the comp, the balance is good.
I like the voc FX. The mix dynamics is reduced a bit too much as pointed out above.
Good effort and well done for trying something different. Reminds me of a kinda West Australian surf/post punk rock sound going on…Tame Impala anyone…good stuff man!
