I found some time to do a bit of mixing. I found some multitracks online, and gave it a go. I don’t know the guy, but I uploaded his mix, just to ask about the brightnes. Mine sounds a lot darker, and, not that I particularly like his mix, but het got it sounding a lot brighter, specially on the drums. And I was wondering how he got it to sound like that. The original drums sound nowhere near as bright as he got them to sound.
ps: I find the vocal technique pretty bad Don’t know the band though
His mix was probably mixed in a better room with more accurate monitoring
His mix is also a lot cleaner and defined. Maybe you should use his mix for a ref because
it sounds pretty bang on to me.
my monitoring environment is very awful. I’ll post a pic with my phone Still waiting till my house is done, to start focussing on a better room On top of that, I only have podfarm2 atm for bass and guitars
But still, doesn’t his snare sound a little boomy? As if there was a room mic that wasn’t properly addressed? of a bad choice of reverb. In any case, it has a tail I don’t like.
But also, on second thought, I think he used the triggers. Cause he also added a trigger file for each drum.
True. I guess the difference lies in how you use the software. Cause I’ve heard plenty of examples where its not THAT obvious. Specially with blast beats and double bass drum patterns.
