Most of what I do is acoustic and I record that way. very little on sound enhancements, basic comprehension throughout, reverb and mono delay on main vocal, reverb on guitar. I normally double mic vocals and guitar, everything else done in the box - bass, piano. before even uploading I realized some timing issues near the beginning soo. I would appreciate your input so I can better this recording and performance.
Thanks
nice fingerpicking
to my ear its all leaning a bit left
nice mellow vibe, sort of a cross between Harry Chapin and Jefferson Airplane
main thing that stoood out to me was that the bass seemed to be way off timing at certain spots in the intro, but ok at others.It was falling waaaay behind the beat like mainly around :24 to :37.
I might have added some background vocals maybe way off in the distance/reverby when that end vocal comes in at 4:22 to the end. Maybe similar to what u did at 1:53ish etc
Peace, JJ
Hey Daniel - sounding good - Iām only listening on cheap speakers at work, but Iād like to have a listen on my studio system when I get homeā¦
Initial thoughts are that I was yearning to hear a little subtle high frequency percussion (eg shaker) to move the groove along, as well as provide a bit of a rhythmic āanchorā for the other elements to circle around as the song develops.
Hi kin Liked the acoustic. Yes, the bass is a little late in a few spots. Liked the vox, but this track could stand alone as well. The vox is also slighty hot. Like the vibrato you put in it. Thanks for posting.
Sincerely
Paul
@Jon-Jon,[quote=āJon-Jon, post:2, topic:1660ā]
[/quote]
I went in and warped some of the timing issues - the vocals were off mostly, the bass was OK, sounds a little better now, I looked at the levels - I must be going about this backwards the levels were slightly more to the right,( OH so thatās what the L & R are for on the headphones) I think I was able to even that out. Weāll see when I up load again with the improvements. I rehearsed some vocals for the background vocals you suggested for the end of the song, sounds interesting. I had not thought of that, good idea, Iāll give it a try - thanks
My interface is shorted out, I have to replace it. Iāve been putting some coin away, a couple - three weeks hopefully. Itās too bad their not repairable. I hate to loose it.
@ColdRoomStudio[quote=āColdRoomStudio, post:3, topic:1660ā]
[/quote]
Yeah! Andrew your making me think here, The percussion would have to change up here and there so as not to be boring. long stroke sound, maybe a couple of other percussion sounds to give that section more body. Iāll open up the GM brush kit and see what can be put together, I donāt have much of anything else - I could spend some time and research the sound library in Cubase over the weekend. OK good.
@feaker[quote=āfeaker, post:4, topic:1660ā]
[/quote]
Hi Paul, Iām glad you mentioned that. I cut back a little on the reverb and the delay to lower the presence of the vocal, It helps from what Iāve heard.
Iāll wait a bit before I upload the song again with the suggestions you folks have offered, so everyone can hear the improvements
Thank you all
Daniel
Had another listen on my studio monitors - still sounding good, recording-wise.
Love those swelling background harmonies. Now that Iām listening in a quieter environment, the timing slips that @Jon-Jon mentioned are more evident - tightening those up and maybe adding some percussion would make an improvement, I think - worth trying!
Nice to have such different and varied styles here!
@Kinfolk
Hi there Daniel,
Some lovely melodic resonances here and Iām liking the twists and turns with light and shade and poetic suggestion.
A few thoughts come to mind while Iām listening. I got a real āstairway to heavenā vibe at the intro, just enough to take my head to a dreamy placeā¦
Iām hearing a slight disconnect with the bass beat in the beginning section⦠now re-listening, Iām wondering just a couple of things⦠ignore me for sure, I do have odd ideas [grin]⦠I wondered about instead of having the bass with a straight āwalking beatā, change it to more of a 1,2,3⦠pause and then a half-beat, or skipā¦you do that rhythm later on in the song⦠The guitar is picking away quickly ( really nice picking I must say!) and my ear tends to try to match the beats a little more.
Some lovely harmonies and a sense of melodic vocal vulnerability which is lovely. There are a few moments where the vox feels just a little pitch-restless, e.g. 1.28 āsomebodyā that caught my ear - having said that, the āhelpless and exposedā bit is lovelyā¦
Really like the transitioning at around 4:00, a nice shift and turning. And the piano end is cool⦠I found myself wanting to sweeten her tone just a little but I AM a compulsive piano tone tweakerā¦
And welcome to the water. Lovely to hear some sounds from you!!. :beerbang:
Hello @Emma,[quote=āEmma, post:7, topic:1660ā]
[/quote]
Iām very much flattered Emma thank you, because this is exactly what I hear in your music. The timing issues are mainly due to my lack of practice. My other life responsibilities have had a tendency to pull me away from the music, Seems I am only able to concentrate properly on one good thing at a time, Iām happy that, that portion of the cycle is ending and I can now devote more time to this passion. Moving forward, the bass is midi so itās spot on timing wise, I do however, like the tip-toeing effect it gives at the beginning, the being cautious. [quote=āEmma, post:7, topic:1660ā]
[/quote]
I hear that now, Yes Iāll need to work that out, Iām not familiar with pitch correction, Iāll only learn it if I do it right?, Iāve been thinking to redo the singing to increase the dynamic range of the performance. Practice is practice.
Emma do you mind if I ask you what you were hearing to tweak in the piano? I do not play the piano.
Hard to believe that I once earned my living as a piano tuner and I never learned to play it, I would gladly receive instructions from a compulsive piano tone tweaker.[quote=āEmma, post:7, topic:1660ā]
[/quote]
Thank you
I could lay down and chill to this.
