I know there are a million different ways to put fades on a region, but I’m can you swipe select or marquee a region in Reaper then hit a button to ‘apply fade’?
If fading the end of a song for example I would like it to draw a fade for any audio within the selected range to fade to the beginning of the edit selected area. This will make all fades begin from the same point but fade to the end of the file even if the regions lengths are not all the same.
I like this feature in Pro Tools and Nuendo because you can be fast and sloppy with it and still have it catch everything.
Oddly I had that very problem yesterday and googled it. I don’t understand the volume envelope master track stuff, but I really only needed to fade one midi track that did not want to work with velocity.
So I rendered it to a wav and faded by hovering the mouse over the top right corner of the track and moving it up and down until a little page cursor appeared and then holding down the left mouse button and dragging it to the right. It took me forever to find that spot as I first thought I could do it from any point in the track.
If I needed to fade out everything at the end, I would render the mix and then fade.
