One of my students asked me if Waves had a saturation plugin. I told them J37 for tape, Scheps Omni for transistor, and ??? for tube.
So 20 min or research and I discovered that the Redd 17, Redd 37 and Redd 51 all have tubes. And luckily are some of the newer saturation plugs where the saturation is decent.
Redd 17 = tubes.
Redd 37 = more tubes (this is the Lenny Kravits/Abbey Road mixer)
Redd 57 = insane amount of tubes.
I always thought Waves sucked at saturation. I found otherwise. The Redd is the only tube saturation in the entire library. For anyone who has this plugin sitting around and hasn’t put it to use, try this.
- First you have to point it at an amp type.
- Second you need to raise your gain and peg the input meter at an adequate level before you’ll hear anything meaningful from the drive
- Reconcile the levels between the drive and the output fader or it’ll give you a nasty digital clipping distortion. Back the Redd 37 fader down first.
- Zero is not unity on the drive. Start with the drive around 9:00 then dial it to taste.
Pretty nice. Huh?
