Everyone has their own way of “glueing” their mix together>
It’s a strange thing, but most of them work, and which you use comes down to personal preference.
My weapon of choice is reverb and, unlike in almost everything else I do in the mixes I create, this one often involves presets.
I have noticed – in the various forums I visit – some confusion among folk about how this particular reverb is used, so I decided to post this quick guide in the hope of making it clear.
You have your mix and you’ve added whatever FX you want to each of the component tracks.
For example: You’ve a nice reverb on the vocals, perhaps you’ve re-amped your guitars and you have eq on almost everything you’ve tracked. It doesn’t matter whether you’ve paralled these fx or inserted them on the tracks (though it does matter what you do with the paralleled ones in the next step.)
The point is, you have a mix. And it sounds good. Hell, it might be almost perfect. It might also sound a little disjointed – nothing sitting well with anything else.
This is where the glue reverb comes in. If your mix is perfect, it won’t detract. If your mix is disjointed, it will glue it together.
Create an aux buss (some DAWs call it a send) as you would for parallel processing and set up your favourite reverb on it.
Make sure only the wet signal is present. (Most reverbs these days have a mix knob).
Now send all the dry tracks, and the track with inserted effects to that reverb.
Turn the gain on that aux buss way up high so you can really hear the reverb and adjust the send controls on each dry track to get the levels well mixed>
Then drop the gain down and down until you can barely hear that au bus output at all.
Now. It may be psychological but when you can barely hear that verb, and you play the whole mix, it all joins up.
The mistake most folks make is to think that this final reverb is going to be the echoey stuff you hear on the track. Far from it. This verb seems to add a little thickness to all the tracks and places them in the same space.
Well. That’s thoroughly confused you – as did finding this post.
Perhaps more later.
For some tracks, it can work nicely when it’s a little more pronounced but only if you’re looking for that effect. I like to use some sort of convolution reverb for this to keep it natural sounding… I’ll sometimes send that reverb buss into a Dimension D for a little movement/modulation, that can be nice sometimes, again track dependant.
