mix1
UPDATE:
mix2
UPDATE 2:
Mix3
Update 3:
Mix4
Did a littlebit more tweaking. Cleared some mud in the lows, altered the room mike so the snare would be a bit fatter, and cut tome more off the toms in the room mike. High passed the bass group a bit higher, and the guitars as well. And also deleted the compression on the 2bus, and only did some limmiting on it.
Hi guys,
I was thinking of doing a new mix first, but I thought, what the heck, thats cheating
This is my first ever mix of a song. In the sence of mixing all the tracks, instead of only adjusting a bit guitar to not sound so horrible
Its my first real effort in trying to get a mix together. I used a mixing guide to help me get a bit perspective and mainly used headphones, since I currently have a very bad accousticly sounding room. Checked on my monitors a few times, after having them headphones on for a couple of hours and starting to feel like being a bathtub. For now there are no automations added yet, I wanted to focus on the sound first. Iām not realy happy with it at the moment. especially the guitar tone sucks, but hey, its plug in, and didnāt change strings so. anyway
Headphones: Sennheiser HD650
DAW: Cubase
I used the build in channel strip saturation of cubase on all string channels, and Iām not sure anymore but I think also on the drum bus.
Guitars:
1 left 100% 1 left 80% 1 right 80% and 1 right 100%
-Iām gonna try and do 2 single guitar tracks next instead fo doubles. And at least trow away one sounnd cause it makes it sound to nasal/cardboard like.
Bass: Center
1 DI track for the subs
1 track with amp sim ( also bias fx ) for nicer mids
1 track with amp sim and distortion ( also with bias fx ) for the (sec most hated word) glue
EQād them all first, then send them to a buss, where I used compression and eq to try and get it to work.
Drums:
Played by the drummer of my band on an electrick kit, and sapled with steven slate drums.
From there on I just whent the same way you would aproach a real kit. eqās and everything.
EQ: fabfilter Q2
Compressors: Fabfilter C and TDR Nova
Reverbd: Fabfilter R
I did some compressing on the master bus wich I kinda regret, but fuck it
So, please bash this hard as I need A LOT of practice with this stuff, and I realy want to master it some day, so give me all the trashing your dirty little minds can persieve
Oh, and the next mix attempt Iāll add the leads onto it.
This track is for my band, and will be used to auditions for a new vocalist. google the bananaexperiment, and youāll see where I got the name. Not that it matters.
As always, screw my english, but enjoy the listen !
Praise jebus
Saturation on saturated/distorted gtrs CAN make them sound smaller. Try setting up a parallel saturation buss and run the gtrs to them so you can turn it on and off and see for yourself if itās doing what you want. While youāre at it, make one for the drums as well. A parallel sat buss can really make your drums slam (if thatās what you want)
and it made me do an EQ on all the tracks saperate with a little bit of brick wall. Then send them all to a buss, where I start with EQ for again high and low pass, then another light brick wall, then 2 compressors in serie, then EQās to get surgical on the mud down below and fret hits in the midās, high midās etc⦠And then again a compressor but multiband, and then again a brickwall
