I can’t seem to find a command that can select a region, then move it up or down one track…(as in to the track above or below in the arrange window). Any know if you can do this?
Not that I’ve found yet, but I’ll keep digging!
You mean select it without cutting it into a separate region? I haven’t used PT in a long time, but I used to select and do some command to create a region/clip from that selection, then just move it up or down tracks. Hold CTRL/CMD to keep the clip moving forward or back in time as you move it.
In Playlists, I was able to comp easily with CTRL-V or something, it would take the selection in the playlist and move it to the main track. That was pretty handy.
