So anyone here have any cheap noise removal software suggestions? I am looking to take out some ambient noise in a jazz piano concert that was recorded live.
All I have is Cool Edit Pro which does a good job, but I have to go back to my XP workstation for that
CEP has a noise footprint functionality and can basically take a sample of just noise and remove from a recording. I am looking for something along those lines.
Reaper comes with a plugin called ReaFIR that will do noise reduction. I guess the trick is always in being able to provide a sample of just the ‘noise’ you want to remove.
If you have the Adobe suite of apps, Audition has semi-decent noise reduction stuff built in. It has the function you’re looking for, capture the noise print then remove, with plenty of options.
I use ReaFIR all the time now. You select Subtraction and check the box, then play a few seconds of the beginning silence for general background noise. Be sure to uncheck the box after, and now your noise is gone.
