Just curious. Has anybody in the history of mixing ever used an EQ to boost 350 Hz?
Thinking of making a 350 bump plugin? Call it the muddifier. You’re welcome
Actually, I’m probably guilty. Seems like I’ve done that before on some female vocals to thicken them up a hair.
Actually, I do have a plugin that takes out 350-500 Hz called “demudder.” It’s not released, but I use it all the time.
my red ibanez with whammy does seem a tad hollow sounding though i havent recorded with it in a while. it might be a candidate for such a boost lol
Yep. You name it, I’ve boosted it.
I generally set up an EQ on my master bus and I filter out everything above and below 432Hz. I wish there was a plugin to make the process easier
Some 300ish on snare if carefully added in can add some serious weight to it. I will sometimes use a distant room mic that is mostly low mids for this. I am essentially cutting out everything else except low mids on this mic. It can get out of hand quickly.
The Mudskipper!
It is generally a frequency you tend to cut, but it’s not without merit. Just try living without it.
Enjoy, #Mixerman
