No brainer alert!! The Black Rooster Audio VPRE-73 preamp for $9!!!
Use voucher ā2018BLACKFRIDAYā during checkout.
Donāt even think about it, just grab it! My favorite saturation plugin right now hands down. This is the first one I reach for when I want to try some saturation or to add warmth and air to a vocal. The hi-pass filter and the high shelf on this thing rock! They call it the āVPRE-73 Silk Editionā for a reason.
Theyāve got some freebies too. The FREE VHL-3C gets some use. Frankly, I forget I have the other 2.
I canāt speak for the other plugins because I donāt own them, but I wish I were spending this BF, because I would pick up the other Black Rooster plugins just based on the quality of the VPre-73 alone. Really great prices right now!
https://blackroosteraudio.com/en/
(Letās see if I can post the email⦠Hey, it worked!)
Magnetite
Magnetite is our homage to the sound of magnetic tape recorders. Simply dial in the desired amount of saturation and warmth and Magnetite will add the analog tape sonics that youāre looking for to your mixes.
Regular: $89
BLACK FRIDAY OFFER: $27
GET THE DEAL
VLA-2A
VLA-2A is the worldās finest emulation of THE opto-electronic compressor of the late 1960s. Awesome on drums, but it also performs outstandingly well on bass or vocals and carefully adjusting the compression really helps to make your signals shine and just sit in the mix.
Regular: $129
BLACK FRIDAY OFFER: $39
GET THE DEAL
VLA-3A
The VLA-3A plugin, is one of the most authentic native emulations of its analog brother from the 70s. This is our goto-compressor for vocals, but it also works incredibly well for bringing out the ambience on percussive material and helping to put some glue into your mixes.
Regular: $129
GET THE DEAL
Blueface SC-5
Youāre looking for a distorted, smashed-up sound on your drum buss? You want to tame lively and dynamic material? The Blueface SC-5 handles it all. The full-blown set of parameters allows you to dial in just the right setting for your application.
Regular: $89
GET THE DEAL
Blackface SC-5
the Blackface SC-5 brings you slightly different compression behaviour, a different harmonic structure paired with a darker sounding audio-path and the option to feed in external sidechain signals.
Regular: $99
BLACK FRIDAY OFFER: $30
GET THE DEAL
Edelweiss`72
Edelweissā72 is a highly dynamic mixing toolchain, that allows surgical modifications to any signal or mix that might sound limply, needs subtle tweaking or a decent finish. Expand, Compress, Limit and EQ your signal with linear-phase filters in regular stereo or M/S mode.
Regular: $179
BLACK FRIDAY OFFER: $54
GET THE DEAL
VEQ-5
The VEQ-5 is inspired by one of the most famous and renowned equalizers in studio history - focussing on the power range frequencies from 200Hz to 7kHz it is aimed at cleaning up and sweetening vocals, guitar and keys.
Regular: $69
BLACK FRIDAY OFFER: $21
GET THE DEAL
VEQ-1P
This plug-in allows for manipulation of the low and high end of the spectrum, without impairing the midrange. The interactive filter network, that features boost and cut at the same time will give the users multiple options of how to treat the shelf frequency.
Regular: $89
GET THE DEAL
VPRE-73
The VPRE-73 plugin is inspired by one of the classic preamps in recording studio history. While streamlining the original processor, we did our best to bring you an authentic emulation of the discrete preamp circuitry and audio transformers, but also retained the high shelf filter.
Regular: $29
BLACK FRIDAY OFFER: $9
