I do not know of a big name ~MIX~ engineer that micro edits their own sessions, and can’t afford an assistant to do it for them. They don’t touch the session until the micro editing is done for them.
??? Hes a producer. Of course he’s going to edit. And he’s gets paid significantly less than his overrated mix engineer counterparts.
Not if their assistants are worth their weight in water.
Look at how things work at MWTM in France. An engineer won’t even throw someones sessions up on the Neve to critique it and demo it until it is MIX READY. That means all the tuning, take comping, fades, labels, all done ahead of time.
What are you talking about? If you want an assistant to edit and prep a mix in Pro Tools, they need pro tools. If you want the signal chain pre-routed to certain plugin chains, they need to have access to those plugins. If you want something autotune, they need an autotune, and if you want them to do it in another room on an editing station, they need a computer. Want them to do it from their house and upload edits to your cloud server repository? That takes gear.
Basically, if someone is willing to invest in more tools, to allow others to better enable others to work with them and for them, so they can do what they do best, they ought not complain about being worn out when they finally get to the mix.
If someone is unwilling to study at the workflow and infrastructure of an established mixing facility and try to understand why their turnover time is so remarkable, then ought to to complain about being unable to duplicate the process.
3 words.
farm. it. out.
