Sounds pretty dope to me !
The guitars sound good to me too!
Thatās some very nice snarling, how much did you have to tweak it? Did you tweak the preset or was it done after the fact?
Hahahaā¦shhh, we were never supposed to tell we used those crappy Behringerās! LOL!! I actually never used them for sims, but lightly on just about everything else. I have no idea why those junkers did so well with conditioning signals to disc. For sims, my best weapons were my Drawmer Tube compressor, a Manley ELOP and then the pedals like the TS808, or some over-drive, or the blue Boss Compressor Sustainer was the best. Thatās the problem with amp simsā¦they lack the buffered signal push like the front end of a real amp has.
So when you drive it a little bit, it can make a world of difference. When I worked for Acme Bar Gig and was developing Shred and Headcase plugins, we did lots of work on the front end of our plugs. We had a few things no one else had at the time that really made an awesome difference in the way the sim behaved. The down side was, it just never sounded or reacted like a tube amp. The up side was, it sounded great as far as transistor sounds go and it also had sustain.
Thatās the huge fault with amp sims and plugs. They give you balls full of distortion, but the sustain just isnāt there unless you jack your monitors to the point of feedback. This is where a stomp box going first can really help. Take like an over drive or the Boss comp/sustainer or a tube screamer, run the output level all the way up, drive all the way down, and mess around with the one up the middle. If you have a little hiss, back the output down a bit. You shouldnāt need any drive from the TS.
Weāve come a long way with amp sims and the like. I have an endorsement with Fractal Audio at the moment and also do quite a bit of beta testing and help with development. Now THAT is an off the hook, sophisticated system! The amps in that are the real deal and the possibilities are limitless. Yeah itās pricey as heck, but itās the last pre-amp Iāll probably ever get. Iāve since sold all my amps because I really donāt need them. Between the AX8, FX8, AxeFxII and the XL+, Iām in heaven over here! The best stuff Iāve ever played through hands down. Anyone in or near NJ, come try them out!
The other thing about amp simsā¦is copping the 12AX7 front end. Iāve not heard many people do this and make it convincing. You can always hear it when you back down a volume or in pinch harmonics. It gives it right away for me. Transistor stuff just sounds weird with backed down volume and the transients donāt clip off as smooth or as warm.
And lastly, cab IRās are huge for getting great tones with sims. There are companies putting them out now that are truly amazing. High passing and low passing on cab IRās is super important too as you can remove that sub low push and sizzle that shouldnāt be in a guitar tone any way. The other thing that can really help is pre-eqā¦before the tone stack or plugin. Eq-ing your signal before it hits the plug with a little dirt pushing the eq level a bit can be huge in tone sculpting. That was one of the cool things about Rocktron stuffā¦they always gave you pre and post eq. I never thought their stuff sounded tubey enough, but I always got great results due to the pre eq. Good stuff.
Pedals probably wonāt be the same Brian. Then again, it depends on which ones as well as what they are capable of. Some of those boutique pedals sounds pretty cool on their own, but still need an amp to really come to life. Driving things in front of them sometimes skewers the sound. A little compression will never hurt though.
P.S. Paul, I meant to tell you before. Iāve since ditched the Behringer comps. Thereās a few good modeled comps in my Midas that give me even better results. Along with the Midas preās, Iāve been extremely happy. It was really amazing how good those Behringer comps worked on guitars and vocals though. All the good outboard gear Iāve had hereā¦and they were just the right thing for a little signal conditioning going to disc. Probably something terrible in their circuitry that degraded the signal just right. Lol!
Reminds me of a guitar track I did for a client. I did a scratch track on my little work computer with a Realtek sound card and ASIO4ALL drivers.
Recorded at 16/44 and something about the way that sound processed just blew me away. When I brought the project into my good gear at my studio, I could not get my sound to quite sound like that. It was so weird!
I was using RME, Lynx and Echo audio I interfaces at the time. None of them got that sound. Lol! Something must have processed through the terrible converters of the Realtek that had a positive impact on dirty guitar tones. Iāve used that a few times for certain things. I guess at the end of the day, it matters not how we get thereā¦as long as we DO in fact get there.
Is that an endorsement or an artist sponsorship?
ā¦can the Fractal be programmed to switch channels on amps?
ā¦does it have routing i/o (or loops) for analog pedals? How many?
ā¦can you freely re-order the insert point at which the outboard pedals are implemented in the chain?
And does the AES port on the back of the unit carry 8 bi-directional channels of AD/DA? In other words, if I were to strap a motu828 to the fractal over 75ohm XLR, could I create 8 independent i/o loops? Or is this only for routing to a DAW? Have you tried this? What about latency?
I was asked initially to beta test as I had not shared with them that I had two world wide released albums, a deal in Japan with Marquee Avalon and other labels in the UK. I donāt really enjoy being forced to use gear like most endorsements make you stick to, so I wasnāt really interested in anything like that. I pay for what I use, ya know? But then one day, I guess they valued what I had to say as well as where Iāve been. I like being a part of the team as I can help make the product better. So playing two positions is pretty awesome.
Iāve never tried to switch channels on amps and do not thing we have that capability. However, you never know. Our pedal boards (MFC 101 and AX 8) have some sick possibilities. I donāt use amps any longer and donāt need extensive switching other than the actual Fractal units themselves. So unfortunately, I canāt really tell you. I have no problems asking if you want me to?
It has loops, yes. You can loop internally as well as control the loops from the software. We have a stereo send and stereo return.
I have no idea on the re-order question as I do not use any external pedals or gear with it.
No on the bi-directional channels. Itās only for routing to a DAW. You can use it as a soundcard/interface as well as a direct box for instant re-amping. There is no latency that Iāve experienced, but I use a console so I never have latency as I do not monitor interface inputs.
@StylesBitchley i just slapped in the plugin and pulled down the bass on the amp settings a bit. then raised the built in limiter a bit too. no more post processing outside the plugin.
wow youre a god danny!!! thanks for the tips
iāll read back on this thread further
Dang! Your den looks even more chaotic than mine haha. This was when I was trying to figure out the amp switching and routing for the wet-dry-wet (left/center/right) rig
Hahaha! I love it Jonathan! It sounds like you may be in need of a switching system. Ever heard of a Bradshaw? I have one hereā¦and RSB 18. Absolutely amazing. This thing does everything.
I have one here in my big rig that I still use today at times. You can trigger amps, old effects, midiā¦itās off the hook. Itās old technology, but was ahead of itās time and is the best switching system Iāve ever used in that respect. Not much need for it these days with the Fractal stuff, but if you are combining amps, effects and loops etc, this thing has 11 channels of mixing board built in along with fx loops all over the place.
Hey @Danny_Danzi, Iād love to get some of your insights on an idea that @Paul999 and I were working on. Iāll start a new thread for it as itās a tiny bit different than what we are discussing here. Regarding pedals/amp sims
Sure manā¦Iāve been waiting to get in on one of those meetings you told me about. Letās get this place jumping!
Are you trying to sell one?
No sir, I was just trying to show you what it looked like as well as close ups on the connections. My big rig (25 space flight case) has some dinosaur effects in it that just sound great. Along with that and the midi I need, Iād be lost without it.
I like the guitar sounds but I think it needs just a bit of a more air on the guitars to be convincing.
Just a touch too dry for my taste.
Yes, there is something about that special moment when the combination of 1ās and Oās allow a sweet preset to sweeten my guitar or my keys. That said I also like the total lack of latency issues that occur with Logic when I mike my Vox amp and play with little or no effects. I still love my reverb in post production. I guess itās a trade off isnāt it! Maybe I have much more to learn yet about latency issues and setup, as I am steel relatively green in the digital world and mixing with headphones and consumer speakers!
Hey @feaker, moved this over here if ya donāt mind
If youāre looking at going the amp sim route, Dave @Chordwainer, Andrew @ColdRoomStudio and I all use Scuffham and are quite happy with them. Theyāre not too expensive either.
Have you tried the Line 6 Pod HD or the Helix? Those are really incredible sounding. I donāt think theyāre as convenient as the plugins, but I think they sound just as good and theyāre way more versatile.
add JonJon to the list of Scuffham āS Gear 2ā users.
I tried in vain for about 2 years to get any amp sims to work but simply couldnt due to lag etc.
3 laptops later I have finally joined the amp sim crowd.
Dont waste your $$$ on Mercuriall Sparkā¦massive noise no matter what you do. I bought it like 18 months ago but my laptop at the time had too much lag. My new laptop will run Mercuriall but its just ridiculously noisey. Makes me seriously doubt the honesty of online reviewers because only 1 or 2 mentioned it but its massive.
I bought the Slate everything bundle which just happened to come with the S Gear 2 sim. I wasnt even expecting it or paying it any mind but lo and behold it works and works great!
Timely because I just posted by first jam with the new SIM and Slate vsts etc
I would have said S-Gear 2 right off the bat if Paul hadnāt asked specifically about free sim plugs in his OP⦠theyāre really good for sure! And because itās not freeware, you get lots more variation and a lot of included āpresetsā with particular combos of sounds, and those are always a great place to start, just cycle through them and see what strikes your fancy, then you can always get āunder the hoodā and start tweaking this or that parameter and just experiment. The other for-money amp sim that I go to just as much is Amplitube (I have v 3 and 4).
But for no-kiddinā zero dollars, the Le Pou sims are hard to beat.
